[Di...] Posted January 6, 2023 Share Posted January 6, 2023 Hello all, I'm trying to create a simple and full digitalization program with export of the final STL to a folder Just to make an operator switch part on machine on a daily shift My program creates the forder and open the same to a easy visualization os.mkdir (r'C:\...') #create the folder os.startfile(r'C:\...') #open the folder Then I export the STL to this folder and the objective is to had Part 1, Part 2 .... I use the export script with record gom.script.sys.export_stl ( bgr_coding=False, binary=True, color=False, elements=[gom.app.project.parts['Part'].actual], export_in_one_file=True, export_stages_mode='current', file='C:/Users/user/Desktop/Produção/teste/Part.stl', length_unit='mm', set_stl_color_bit=False,) On this script I try to add a count function but with no success and after a few try I try to change the exportations stl names on the folder for file_name in os.listdir(folder): source = folder + file_name destination = folder + 'Part_' + str(count) + '.stl' os.rename (source, destination) count =+1 But with this code he creates the Part 1 and Part 2 but on the 3 run he change the names of the parts to Part 3 and Part 4 and had one new export with the name Part 5 for a program while (count < 3) Is it possible to had the rename process on the export script?? Link to comment Share on other sites More sharing options...
[Di...] Posted January 11, 2023 Author Share Posted January 11, 2023 Please sign in to view this quote. Problem solved Thank you Link to comment Share on other sites More sharing options...
