.stp file size
Sometimes when we convert a solid model to a .step or .stp file, the size is much larger than normal. Usually the step file is less than 1 or 2 MB. I have some files that are as much as 20MB. My surfaces are freeforms and with the larger files the analysis for GDT Profile can take up to 20 or 30 minutes.
We have tried a few things to get the files to convert to a more normal size but haven't been successful.
Any suggestions?
The only thing that I could think of was, try saving the model as a different format
(.iges, sat, sab, etc)? I've had better luck using .iges files instead of .stp/step.
