Parameter (not defined)
My postsetting
//Dims to Excel
filePath = "T:\DMR\CMM Data\Medtronic\Diameter_.1247 (feature 200)\"
ext = ".csv"
//N1 = getRecordHead ("PCM_.0934_CFS_Rev. C")
//dirPath = filePath + N1 + (" ") +date()+" "+time()+ ext
Lot = getRecordHead("order")
partnum=getRecordHead("partnbinc")
dirPath=filePath+Lot+("_")+partnum+ext
display(dirPath)
if fileExists(dirPath) == true
deleteFile(dirPath)
endif
//#1
DIM200_1 = getActual("200a").actual
//#2
DIM200_2 = getActual("200b").actual
addToFile(dirPath,date())
addToFile(dirPath,time())
addToFile(dirPath,("T:\DMR\CMM Data\Medtronic\Diameter_.1247 (feature 200)"))
addToFile(dirPath,("Lot Number : "),LN)
addToFile(dirPath,("200a : "),DIM200_1)
addToFile(dirPath,("200b : "),DIM200_2)
The error message.
Clarke,
You defined "Lot" and "partnum", but you failed to define what "LN" is. Simply add a line of code to the effect of :
LN=Lot + partnum
Make sure you add it above the "addToFile" commands.
Keith
