[Li...] Posted January 2, 2020 Share Posted January 2, 2020 How do you get Calypso to report the bottom diameter and the top diameter of a cone? Calypso gives me the bottom of 3.7445" I also need the top diameter of 3.820" per the print. Thanks Lincoln Link to comment Share on other sites More sharing options...
[c0...] Posted January 2, 2020 Share Posted January 2, 2020 Construction > Cone Calculation > select at which height you require the cone diameter, relative to either cone/feature origin, Base Alignment, or select another feature. Link to comment Share on other sites More sharing options...
[Li...] Posted January 2, 2020 Author Share Posted January 2, 2020 Thank you Laura! Lincoln Link to comment Share on other sites More sharing options...
