[SH...] Posted January 1, 2020 Share Posted January 1, 2020 What are the corner points, what does it means?. IMG_20191226_143100.jpgFetching info... Link to comment Share on other sites More sharing options...
[Er...] Posted January 1, 2020 Share Posted January 1, 2020 The four corners of the grid.. Link to comment Share on other sites More sharing options...
[SH...] Posted January 2, 2020 Author Share Posted January 2, 2020 Please sign in to view this quote. What is the significance corner points, flatness is dependent on peak and vally points?? Link to comment Share on other sites More sharing options...
[Er...] Posted January 2, 2020 Share Posted January 2, 2020 I guess nothing for the actual flatness value it self, theres a lot of information showing in piweb that might or might not be relevant. I think its Zeiss trying to flex the muscles of piweb showing how much more its capable of then the old reports. Some times the flexing just might be confusing. I dont know but I guess the corner points is the same as the nominal plane you have measured, if thats the case, it could give a hint of how much coverage you have of the plane. If thats the case I can see why they are presented. Link to comment Share on other sites More sharing options...
[An...] Posted January 2, 2020 Share Posted January 2, 2020 Please sign in to view this quote. It's an envelope that gives you the chance to evaluate the orientation of the derived feature. (beyond all normative rules). See attached. Contribution_02_01_2020.pdfFetching info... Link to comment Share on other sites More sharing options...
[Er...] Posted January 2, 2020 Share Posted January 2, 2020 Ehh? The orientation should be derived from the feature in this case? Refering back to A and/or B must be an assumption that can be wrong? Link to comment Share on other sites More sharing options...
[An...] Posted January 2, 2020 Share Posted January 2, 2020 Please sign in to view this quote. Weird thinking of mine! This plot data might help the machinist to correct the travel of the tool. Calculating any kind of Perpendicularity is misleading. Sorry! See attached. Contribution_02_01_2020_a.pdfFetching info... Link to comment Share on other sites More sharing options...
