straightness with Datum
It's hard to know how the part is meant to function without talking with the designers. But if you are using Calypso, you can do a position tolerance that evaluates the derived median line like a straightness tolerance does and reference datum A. That might reflect something like that. It's hard to say though because the tolerance applied doesn't make sense according to any current standards. If you could call and ask what they are looking for, that would be your best avenue instead of just guessing.
Except for when there is. Like in the case of straightness, Or in the case of how Calypso evaluates derived median lines. Your issue is how to calculate the center point of each cross-section where the median line comes from. That is a separate problem that isn't well defined in my opinion. But that doesn't mean there is no derived median line. It's the official term for a line that passes through all the cross-sectional center points of a cylindrical feature. So.. its a thing.
