After homing...
Since my last calibration, when I home the CMM the machine takes off toward the middle of the granite and stops near the surface. Obviously it was something the tech did, but how do I set the CMM to stop at the homing location when it finishes the homing run?
I have a Contura with an RDS and a Vast XXT system, running Calypso 2018.
Thanks in advance!
Thank you!
Edit: if there are any other noobs with this question, I just discovered when homing a warning pops up to ensure the machine is clear before homing, you can also set the x,y,z co'ords to zero("Move to after home") in this window before clicking ok.
