Para files
Unless you have something that needs execution in your .para file, I recommend using readPCMFile() over runPCMFile() when only setting variable values. Reason is simply efficiency.
Have you set your diameter on the feature inside Calypso to a variable, a variable that change its value depending on what .para file you read/run?
To give a definite answer to your question I need to see both your feature in Calypso and your .para files.
https://qualityforum.zeiss.com/topic/16980-para-files/#findComment-94988
