Para files
Unless you have something that needs execution in your .para file, I recommend using readPCMFile() over runPCMFile() when only setting variable values. Reason is simply efficiency.
Have you set your diameter on the feature inside Calypso to a variable, a variable that change its value depending on what .para file you read/run?
To give a definite answer to your question I need to see both your feature in Calypso and your .para files.
Ah, theres your problem, one variable is called Dia_1 and the other Dia_2. The variable name shall be same as the one in Calypso. In your case as it is now, Dia_2.
So dont use Dia_1 as variable name. Only use Dia_2.
And have a nice christmas!
