[Gr...] Posted May 15, 2019 Share Posted May 15, 2019 Our O-Inspect lights won't come on unless we close Calypso and restart it. So when we close a probing program, and open an optical program, without restarting the lights won't come on. Any ideas? Thanks, Link to comment https://qualityforum.zeiss.com/topic/17020-o-inspect-light-problem/ Share on other sites More sharing options...
[56...] Posted May 15, 2019 Share Posted May 15, 2019 What model of O-Inspect (322, 442, 563...etc) and which version of Calypso are you running, along with what service pack? Link to comment https://qualityforum.zeiss.com/topic/17020-o-inspect-light-problem/#findComment-95198 Share on other sites More sharing options...
[Gr...] Posted May 15, 2019 Author Share Posted May 15, 2019 Hello Laura, It's a 322. Calypso 2018 Version 6.6 No service pack is listed at the machine but I do have QS-Stat Interface 1.97 in the off line seat (which of course you cannot O-Inspect with) Link to comment https://qualityforum.zeiss.com/topic/17020-o-inspect-light-problem/#findComment-95200 Share on other sites More sharing options...
[Jo...] Posted May 15, 2019 Share Posted May 15, 2019 Greg, try checking your camera's wire connection in your computer and make sure it has the correct configuration setup in calypso software. Link to comment https://qualityforum.zeiss.com/topic/17020-o-inspect-light-problem/#findComment-95202 Share on other sites More sharing options...
[No...] Posted May 16, 2019 Share Posted May 16, 2019 Which Windows version? If Windows 10, which update release? It may be a Viscan driver issue. Link to comment https://qualityforum.zeiss.com/topic/17020-o-inspect-light-problem/#findComment-95204 Share on other sites More sharing options...
[Gr...] Posted May 16, 2019 Author Share Posted May 16, 2019 Windows 10 Version 1803. I like this idea. I'll go to the Zeiss portal and see if there is an updated driver. The system does work but only from a fresh boot. No jumping back and forth. Link to comment https://qualityforum.zeiss.com/topic/17020-o-inspect-light-problem/#findComment-95206 Share on other sites More sharing options...
[No...] Posted May 17, 2019 Share Posted May 17, 2019 As far as I know that driver isn't available for download seperately. We already had Windows 10 on our O-Inspect when the IT updated it to 1709. After that the lights and camera worked no more. But this was Calypso 2017. I don't remember if it worked with 2018. Anyway, I got a new driver from support. To be exact, it wasn't the Viscan driver, but the Viscan dongle driver. Link to comment https://qualityforum.zeiss.com/topic/17020-o-inspect-light-problem/#findComment-95208 Share on other sites More sharing options...
[Gr...] Posted May 17, 2019 Author Share Posted May 17, 2019 Yes I learned that there was no separate driver yesterday. I'll call in and see what they can go. Thank you Link to comment https://qualityforum.zeiss.com/topic/17020-o-inspect-light-problem/#findComment-95210 Share on other sites More sharing options...
[Gr...] Posted December 17, 2019 Author Share Posted December 17, 2019 Just wanted to pass along an update on this. The problem was solved by updating to the newest service pack. I can't say what the problem was, if it was a corrected bug or just a glitch in the system but all is well now. Link to comment https://qualityforum.zeiss.com/topic/17020-o-inspect-light-problem/#findComment-95212 Share on other sites More sharing options...
