probe selection
Trying to figure out what type of probe to buy to check this slide in a 9mm pistol.... I was thinking a disk probe but wasnt sure if i could measure the .100" height of the slide.....Do any of you guys have a suggestion for what you think is best.....
Thank You
1911_PROBE_SETUP.pdf
From what I understand, disk probes are only good on the edge - the top and bottom don't get calibrated.
Personally, I would use a little star or L probe, depending on what kind of head you have.
But really, it is going to depend on how much access you have from surrounding features, and the tolerances you need to hit.
Don't forget - sometimes a CMM is not the tool for the job. A height gauge might work better for at least some of the measurements.
RDS head with vast xxt....
I wound up building a 100x90x1.5mm probe and using 172.5 and -172.5.......worked great....
I appreciate any all help....Thanks
