[Ma...] Posted January 13, 2023 Share Posted January 13, 2023 Hello, Is it possible, and how to do it if possible, to make a button for let the user choose if launch a script and then run it? Thank you in advance! Link to comment https://qualityforum.zeiss.com/topic/1706-how-to-create-a-button-in-a-dialog-box-for-launch-a-script/ Share on other sites More sharing options...
[Di...] Posted January 18, 2023 Share Posted January 18, 2023 hello You can use the library Tkinter were you create a box with a button and if the user chose ok the script start if not the script fail Or you can use a script dialog like this one RESULT=gom.script.sys.execute_user_defined_dialog (dialog={ "content": [ [ { "columns": 1, "data": "AAAAAA==", "file_name": "", "height": 0, "keep_aspect": True, "keep_original_size": True, "name": "image", "rows": 1, "system_image": "system_message_warning", "tooltip": { "id": "", "text": "", "translatable": True }, "type": "image", "use_system_image": True, "width": 0 }, { "columns": 1, "default_font_family": "", "default_font_size": 0, "name": "text", "rows": 1, "text": { "id": "", "text": "<html><p>Execute Script?</p></html> Link to comment https://qualityforum.zeiss.com/topic/1706-how-to-create-a-button-in-a-dialog-box-for-launch-a-script/#findComment-6554 Share on other sites More sharing options...
