[Ky...] Posted December 12, 2019 Share Posted December 12, 2019 I have an angle callout that is to the intersection of a plane to a cylinder. I pull up intersection from construction. Click on the plane and the cylinder. I check the shell box on the cylinder, but it won't give me the intersection. the cylinder continues on after the plane at the below the step as shown in the 3rd pic. How do I find this intersection? Thanks KyleAngle callout 2.pngAngle call out.pngAngle Call out Print.png Link to comment https://qualityforum.zeiss.com/topic/17062-can-not-get-intersection-from-plane-to-cylinder/ Share on other sites More sharing options...
[To...] Posted December 12, 2019 Share Posted December 12, 2019 Try a line instead of a plane. Link to comment https://qualityforum.zeiss.com/topic/17062-can-not-get-intersection-from-plane-to-cylinder/#findComment-95434 Share on other sites More sharing options...
[Ky...] Posted December 12, 2019 Author Share Posted December 12, 2019 Thanks Tom that worked. Wouldn't have thought of using line thought I had to have a plane to a cylinder. Learn something new everyday. Link to comment https://qualityforum.zeiss.com/topic/17062-can-not-get-intersection-from-plane-to-cylinder/#findComment-95436 Share on other sites More sharing options...
[Ri...] Posted December 13, 2019 Share Posted December 13, 2019 Also using a Curve, and the kink point of the theoretical line & circle works well too. Link to comment https://qualityforum.zeiss.com/topic/17062-can-not-get-intersection-from-plane-to-cylinder/#findComment-95438 Share on other sites More sharing options...
[Ke...] Posted December 13, 2019 Share Posted December 13, 2019 I'm pretty sure that you can also throw in a theoretical plane, that intersects the plane & cylinder; if you want to use the entire feature(s), or if you are already measuring the entire surface(s) for another evaluation Link to comment https://qualityforum.zeiss.com/topic/17062-can-not-get-intersection-from-plane-to-cylinder/#findComment-95440 Share on other sites More sharing options...
