Angle in minutes
Thats one shitty drawing... 😱
Your missing some vital info, how ever, I'll try to fill in the blanks with assumptions.
Let's assume that slot (or what ever it is) is 40mm long. Then we use tan­­¹(0.2/40). That gives us 0.2864765102770745°.
0.2864765102770745*60 is 17'.
If you like to know the remaining seconds, 0.18859061662447*60. That's 11''.
So 0°17'11'' if the lenght is 40mm.
Keep in mind that angularity isn't a tolerance of the angle it self. And the result isn't a angle of any kind. It's the width of the tolerance envelope.
It basicly keeps orientation under control at a basic angle. With that in mind. Good luck.
You can change the settings so that Calypso outputs the to minutes and seconds, to do it globaly you would go to settings>environment>language. If you want to have it only for that single program go to the measurement tab>Measurement plan editor features and from the drop down select units>angle.
