How to Display Tolerance Zones in CAD?
What is the key to seeing the tolerance zones on the CAD model after you have all of the features and characteristics created? I've tried checking the "Show Tolerance Lines" and turning on "Show Graphic Result Display", but I seem to see the tolerance zones on the CAD model intermittently. What is the right combination? I'm using Calypso 6.6.
I got this from a Zeiss service tech, and it was the part that I was missing.
CAD>Evaluation check the display box. With this window open go ahead and highlight a characteristic and in the evaluation window you can check a box for tolerance frames. This will allow you to visualize the tolerance frame.
