Problem with Calypso userfields and QC-calc factors
Hello,
We are using QC-calc as our database for metrology results. I have defined userfields/factors we need for tracebiality and forced them to go in certain TXT factors in QC-calc.
I have created 2 different printout header templates: autorun and facs templates.
I have defined that autorun template uses userfields:
- Process order, Comment and Sub Batch
Same for FACS template. I have defined that FACS template uses userfields:
- Mould_ID, Measuring Equipment, Fixture_ID, Part name and drawing number
I want to use two different kind of databases which has different factors --> databases would be program specifics.
Problem is that Calypso takes always all the factors defined inside the userfield.ini to QC-calc. Is it possible to create and use 2 different kind of databases parallel?
Below view of Calypso SPC database how it looks like atm.
Any good advices?
Best regards,
Teemu
I don't know a thing about QC-Calc, so first of all: How is the data transferred to QC-Calc? Are you using the QDAS output option or does it read the Calypso files directly? If you're using QDAS there's a hidden option to have two different sets of data files generated. It involves a batch file in the config folder and a seperate QDAS config file.
See QC-Calc -->Help --> Machine Specific Help, Zeiss, Passing Non-Measurement Data to QC-Calc
You will need to tell QC-Calc to collect those fields by adding them to:
Administrative Tool --> Edit Application Defaults --> Then Edit the line for "CalyTxtFactors" to inclue the new fields.
Separate values with the | symbol.
IE: "Process_Order|Comment|Sub_Batch|" etc.
