[Ad...] Posted November 18, 2019 Share Posted November 18, 2019 We updated our Calypso software to 2019 now I'm not able to figure out how to get Calypso to start up in Autorun for an individual User profile. What am I missing? Link to comment https://qualityforum.zeiss.com/topic/17226-startup-in-autorun/ Share on other sites More sharing options...
[Cl...] Posted November 18, 2019 Share Posted November 18, 2019 Extras > settings > environment > Start Link to comment https://qualityforum.zeiss.com/topic/17226-startup-in-autorun/#findComment-96474 Share on other sites More sharing options...
[Ad...] Posted November 18, 2019 Author Share Posted November 18, 2019 The settings appear to be global for this....I don't see the pull down that was in previous versions to set it up per user Link to comment https://qualityforum.zeiss.com/topic/17226-startup-in-autorun/#findComment-96476 Share on other sites More sharing options...
[Cl...] Posted November 18, 2019 Share Posted November 18, 2019 You should be able to change per user. Link to comment https://qualityforum.zeiss.com/topic/17226-startup-in-autorun/#findComment-96478 Share on other sites More sharing options...
[Ad...] Posted November 18, 2019 Author Share Posted November 18, 2019 That dialog box is what the previous version looked like, in 2019 I can't find the per user option like your dialog box. Link to comment https://qualityforum.zeiss.com/topic/17226-startup-in-autorun/#findComment-96480 Share on other sites More sharing options...
[To...] Posted November 18, 2019 Share Posted November 18, 2019 I don't have 2019 yet, but I would guess you have to log in as Master. Go to the User settings window. From there, switch to the desired user. Then, go to the Environment window (as the desired user) and establish startup settings. I'm guessing maybe the only difference is that it does not say "Environment for Desired User".... They must be assuming the Environment" settings are for the currently logged in user. Link to comment https://qualityforum.zeiss.com/topic/17226-startup-in-autorun/#findComment-96482 Share on other sites More sharing options...
[Ad...] Posted November 18, 2019 Author Share Posted November 18, 2019 Please sign in to view this quote. That was correct....I needed to reset privileges for the user to allow Environment Setup...then I was able to update the startup conditions...after complete I just changed the privileges back. I'm pretty sure the old version I was able to switch these settings without using individual logins but it's been so long I'm not 100%. Thanks for the help Link to comment https://qualityforum.zeiss.com/topic/17226-startup-in-autorun/#findComment-96484 Share on other sites More sharing options...
