Multiple items 3D Models scanning
Good morning all!
I've never succeded doing a pallet program and whenever i try i'm having issues moving the 3D models around in the Calypso interface, so i'm actually leaving it there and i'm doing 100 items scan one at time... how could I move the models indipendently from each other? How can i have a report with all the items scanned?
I'm pretty new here, so go easy with me 😃
A pallet program can only be run in the auto-run interface of Calypso.
You should only need one model and one program (if they're all the same part) and then put that program into the autorun pallet interface and select the positions of the pallet each part will be placed at. Then, autorun will run as many parts as you select uninterrupted and will report an individual measurement report for each part.
Unfortunately, I've yet to see a good and conclusive set of instructions on using the autorun interface. There are lot of good instructions that will help get you started.
Ian Ranly.2 posted a couple of autorun instruction documents in this thread.
viewtopic.php?f=13&t=2305&hilit=autorun
Go thru them instructions and don't be afraid to ask more specific questions if needed. Seems like there are more questions on this forum about auto-run than anything.
