RSH Sphere collision issue
I'm setting up a Micura with a Vast xtr gold head. I've set up the RSH sphere and have done the shaft definition as well but I am having trouble qualifying some styli. The -Z probe will hit the shaft and alarm the machine out while qualifying the -X probe. Not sure what I am doing wrong? This is mty first time using the RSH style reference sphere.
You can loosen the top section of the reference sphere and rotate it so that you can affix your sphere to the very top of the base (the reference sphere will be straight up and down, instead of at an angle). Then, when you qualify with the master, tell it the reference spheres tilt is 180 degrees and rotation is 0 degrees. This should get you in business!
Keith
