Circle in Contour Fit
If you are using it to create an arc (circle) from a 2d curve, it works great.
Although you can achieve the same thing using Tangent and a couple of lines.
I was using it to create an arc from a 2d curve, it's just one of them day's when you spend an hour trying to figure something out in vain. 😡
The problem was that I was using it from a recalled section of the curve and didn't realize I forgot to name that recalled section accordingly and was trying to use the whole curve....smh 🫣
That's what happens when you make a quick program (with a lot of features and curves) thinking it would probably never be used again.
Oh well, tomorrows Friday 😃
