Can someone tell me what this second line means
Thank all of you for your answers . And thank you Richard S. Richard told me about the P button to set the project distance. From all the above posts it shows my projection starts at the top of the part and goes .500 above the part. I didn’t show the part because I can’t, but the part is .375 thick and the hole goes all the way thru with the c’sink at the top. When I hit the P button it shows .500 (P). But it starts from the bottom of the part. How do I get it to start form the top of the pat like it shows in the illustrations above. Again thank all of you for your time in helping me.
I'm not in an industry that uses projection, so I've never used it in Calypso, but I would imagine it matters what the vector orientation is. Did the projection go with the vector, or against it? And can you input a negative value in the projection window? I don't have a Calypso seat just yet to test.
