[Cl...] Posted November 12, 2019 Share Posted November 12, 2019 I have a hexalobe (six sided star) Go-NoGo gage used to check screws. I am scanning 2d curves around the OD and recalling those points into circles. Evaluating them as max inscribed/min circumscribed to get the major/minor diameters. Inside each curve I did a best fit/parameters/alignment (would I tick translate X&Y, or rotate about Z)? Do I then create an alignment from the curve and use it for the circles? Is this the correct way to approach this, or is the best-fit even necessary? My goal here is to optimize accuracy. Link to comment https://qualityforum.zeiss.com/topic/17280-circles-from-curves/ Share on other sites More sharing options...
[Is...] Posted November 13, 2019 Share Posted November 13, 2019 not sure about the purpose of your curves but just consider best fit adjusts the actual values (no the nominals) then if you extract some dimentions from a best fit curve (i.e. using intersections) the values are not accurate. Not the case with recall Points, however if you plot the curves, what you will see in the graphic will be different than what you see in the data.. Link to comment https://qualityforum.zeiss.com/topic/17280-circles-from-curves/#findComment-96798 Share on other sites More sharing options...
[Cl...] Posted November 13, 2019 Author Share Posted November 13, 2019 So then what/how would I use this option? We have a worn hexalobe gage used to check screw heads, and are trying to get the actual major and minor diameters of this gage. Link to comment https://qualityforum.zeiss.com/topic/17280-circles-from-curves/#findComment-96800 Share on other sites More sharing options...
[Me...] Posted November 13, 2019 Share Posted November 13, 2019 If I'm not mistaken, if you're scanning these curves based off a model, and an accurate model to boot, in training we were taught NOT to use Best Fit on Curves. I specifically asked about that in the Curve refresher course I took 2 years ago. Link to comment https://qualityforum.zeiss.com/topic/17280-circles-from-curves/#findComment-96802 Share on other sites More sharing options...
[Cl...] Posted November 13, 2019 Author Share Posted November 13, 2019 OK, based on that, I'll stay away from that approach. Link to comment https://qualityforum.zeiss.com/topic/17280-circles-from-curves/#findComment-96804 Share on other sites More sharing options...
