Projection angle confusion
In this case your space axis is X.
A1 Y/X - nominal angle is -0.1180°, actual -0.0878° is a positive direction or X rotates clockwise around Y axis
A2 Z/X - nominal angle is 0.4000°, actual 1.1727° is a positive direction or Z rotates clockwise around X axis
Easy way to visually see the direction of rotation would be to add 5° to either the A1 or A2 nominal angles and you will see the feature origin rotate.
The nominal should be 00.00, actually I never mind about nominal value in the feature menu, I correct it in my output characteristic area. The nominal value can affect the output result??
Ohh my goodness, I will keep an eye on it.But my machine moving in correct direction,I did not face any abnormality eventhough I did not correct the nominal value.
The nominal angles you have are pretty small so you probably wouldn't have notice much of a difference of the vector approaching the feature. You should still change them to zero.
