[Jo...] Posted October 30, 2019 Share Posted October 30, 2019 what would be the best way to create this gage dia.?GAGE.PNG Link to comment Share on other sites More sharing options...
[To...] Posted October 30, 2019 Share Posted October 30, 2019 Create your cone feature. Then, create a Cone Calculation, found under the Construction menu. Assign the cone feature to the Cone Calculation (Cone Addition). Select Position Definition and enter 8. This will create a theoretical circle feature with a diameter of 8. Use a Cartesian Distance to measure .12 distance from the Cone Calc feature to the plane. Link to comment Share on other sites More sharing options...
[An...] Posted October 31, 2019 Share Posted October 31, 2019 Create a bunch of theoretical lines at the circumferential line of the diameter 8 in order to achieve intersection points on the cone surface. Report the minimum- and the maximum distance of those points. Regarding dimension 2.28 Link to comment Share on other sites More sharing options...
[Da...] Posted October 31, 2019 Share Posted October 31, 2019 Not related to OP, but I'm wondering why did they put datum A on outer cylinder Ø 4.00 instead of inner cylinder Ø 3.15 Should be more stable right? Link to comment Share on other sites More sharing options...
