Is this a torus?
I have a part as shown in the image attached. I am tasked with measuring that radius but the center is offset. I am told that this is a sphere, Calypso says it is a torus. If I measure it as a torus and report the second radius, the results are often slightly large. Measuring as a sphere and reporting radius, results are small.
What shape is this and what is the best way to report that size?
Measure the outer diameter or inner cylinder and set it as the primary alignment.
Then measure the shape as a sphere and you will get the values you are looking for.
You can convert the diameter of the sphere into a radius in a formula
It is a Torus, but it looks like the "major" diameter is actually smaller than the "minor" one, which is unusual. A sphere, though, is the special case of a torus where the two are equal.
Calypso will recognize this as a Taurus. To get the radius you need I would make a circle under
creating features under CAD pull down. 333_72714974f717f64c284d14dcd59fd598.jpg
Open the section pull which is where you define the sectioning plane.
You can manipulate size by grabbing corners with mouse then hit section.
A yellow line shows the places the features are cut 333_5e930bd7391fe1d1021018fa691ddf48.jpg
After you do this go to creation and with mouse click on the yellow line that represents feature you need.
It will turn purple. Un-click Full circle then click the circle icon. A circle will be created under features 333_41517fa9eed64d7ccc03d4c488478444.jpg
you can now open up the circle and edit your strategy and evaluation 333_78badc635df2c927ad50a45b59420e04.jpg
Hope this is helpful and not too long winded
If I was the designer wouldn't request a radius measuring there (Line Profile is better)..
the measuring will have a very big uncertainty anyway...
you have some tools to find the value that you are looking for here:
By the way, you can't trust Calypso's identification of CAD geometry, because Calypso always approximates.
If you need to know the real geometry type of a CAD patch and have no CAD system available, you need at least some kind of CAD viewer that allows to turn approximation off.
Gregory got it. I overlooked the Creating Features menu. I tried creating curves and then recalling into circles. I didn't realize that through a Section I can simply define a circle.
As far as offline is concerned, this is looking much better. Will update when I run it online. Thanks Norbert for letting me know that Calypso isn't always spot on.
It should be a Torus, sphere radius should be marked as SR not symbol R. Using curved tracing you can easily find the radius, I don't think this is much complicated....
