[Gr...] Posted October 29, 2019 Share Posted October 29, 2019 OK Just got squared away with how to go about making the RT05 rotary table C98 controller working together now the CMM is acting up. It is a Prismo MPS HTG using the above mentioned controller. End of September a Zeiss tech came out to fix and calibrate it and ended up replacing the Vast Gold head and scale for Y axis. Everything was fine until an hour ago. When Calypso is set up for English as language machine will not home. It actually turns the drives off when homing in Y. Switch Calypso language to MM it goes home no issues. Everything we do here is in English measurements and would like to keep it as a Calypso default. Attached is a picture with all the error messages the machine gives when locking up. Link to comment Share on other sites More sharing options...
[Gr...] Posted October 30, 2019 Author Share Posted October 30, 2019 This situation does not seem to be the same as the 10/29/19 posting about drives shutting off. There are different codes in the status window. Greg K Link to comment Share on other sites More sharing options...
[Ri...] Posted October 30, 2019 Share Posted October 30, 2019 What version of Calypso are you on? You may need a service pack. Just a shot in the dark. Typically if you are having hardware issues, I would strongly suggest to call Zeiss. Link to comment Share on other sites More sharing options...
[Gr...] Posted October 30, 2019 Author Share Posted October 30, 2019 This is an older Prismo. It has a C98 controller and Calypso 5.6 because, as we were told, this is the latest version that will work with this said controller. It has had a new scale, Vast Gold Head, and calibration completed 9/27/19 and worked up until yesterday afternoon. Link to comment Share on other sites More sharing options...
