[Wi...] Posted October 28, 2019 Share Posted October 28, 2019 I dont know why i cant get this to work today. I have had success with iterative alignments before and I am pretty sure i have looped just a plain ole 321 base alignment. I keep getting an error and program will not even run... any help would be much appreciated. Here is a pic of the error im getting. Thanks in advance for any and all help π Capture.JPGFetching info... Link to comment Share on other sites More sharing options...
[Jo...] Posted October 28, 2019 Share Posted October 28, 2019 baseSystem().valueA<0.005 must have leading zero before decimal, move that decimal over one place. It will never meet 0.0005 Link to comment Share on other sites More sharing options...
[Wi...] Posted October 28, 2019 Author Share Posted October 28, 2019 Even in inches Link to comment Share on other sites More sharing options...
[Wi...] Posted October 28, 2019 Author Share Posted October 28, 2019 Thank you sir.... thats all it was Link to comment Share on other sites More sharing options...
[Jo...] Posted October 29, 2019 Share Posted October 29, 2019 Please sign in to view this quote. You can loop it 10 times and view default printout. It will show the value there. Usually after the third time the results are pretty small, but it will give you an idea of what is possible. It will continue after your maximum loop count anyway. Link to comment Share on other sites More sharing options...
[Wi...] Posted October 29, 2019 Author Share Posted October 29, 2019 I did just what you said..... Put 5 iterations in formula and set it to 0.0005".... It got it after the 3rd iteration. I even bumped my pc i was using to test it and it worked perfect. Thanks again for all the help. Stupid zero π Link to comment Share on other sites More sharing options...
