Save text file with PCM
I'm not 100% sure what you're asking for, could you explain in more detail?
Do you want all reports to go into the same folder?
If so then your "BASE_NAME" which is probably planid + pallet ID should not include the Pallet id.
the problem is that I have this PCM code
Step 1.- generate a CHR file with this feature.
step 2.-generate the necessary information that my file asks to see the image Save 1.2
Step 3.- Mark an error and I can't find how
request remove this problem view image Save 1.3
and 1.4
Step 4.- when reviewing the file that was generated I realize that the desired information if you are seeing the image Save 1.5.
The problem is that error I wish to run automatically
