[Me...] Posted October 25, 2019 Share Posted October 25, 2019 good morning I did not find information about this example of PCM as I can do to generate the text file once and the other repetitions are saved the same text filePCM 1.pngPCM 1.2.pngPCM 1.3.png Link to comment Share on other sites More sharing options...
[Ro...] Posted October 25, 2019 Share Posted October 25, 2019 I'm not 100% sure what you're asking for, could you explain in more detail? Do you want all reports to go into the same folder? If so then your "BASE_NAME" which is probably planid + pallet ID should not include the Pallet id. Link to comment Share on other sites More sharing options...
[Me...] Posted October 26, 2019 Author Share Posted October 26, 2019 the problem is that I have this PCM code Step 1.- generate a CHR file with this feature. step 2.-generate the necessary information that my file asks to see the image Save 1.2 Step 3.- Mark an error and I can't find how request remove this problem view image Save 1.3 and 1.4 Step 4.- when reviewing the file that was generated I realize that the desired information if you are seeing the image Save 1.5. The problem is that error I wish to run automaticallyGuardar1.1.pngGuardar1.2.pngGuardar1.3.pngGuardar1.4.pngGuardar1.5.png Link to comment Share on other sites More sharing options...
[Ro...] Posted October 26, 2019 Share Posted October 26, 2019 Im not spotting an obvious problem but i do see your FULL_OUT appears to be correctly formed but your errors in 1.3 & 1.4 show your directory as C:\temp\C:\Temp.fghfdghfgdhgh.JPGmhgfhkgf.JPG Link to comment Share on other sites More sharing options...
