Programming New Rack(socket)
Hello Everyone,
Good morning,afternoon,evening.
We have a Zeiss Contura with a VAST XXT RDS Head and I'm trying to add an additional rack to our setup here.
It would be really awesome and helpful if someone could walk me through it or share ideas on how to proceed with it. We already have 3 probe rack(socket) and the one I'm trying to add is the same.
This is the one -
https://shop.metrology.zeiss.com/INTERS ... gID=400000
Thanks in advance. 😃 😃 😃
Open up your automatic stylus system change, in the top left where it says edit choose "add stylus system holder" decide on the name of the holder. Then put on your Master probe and select the new rack and in the drop down to the right of edit select "define holder location". This will walk you through defining the location of the rack, which will have you probe the spot on the holder. At that point its basically set up, you will then choose one of the holder slots and in that same drop down select "set stylus system to stylus system holder" select whichever probe you want in there.
  • Like! 1
