Perpendicularity/No result
I have a 0.0001 perpendicularity callout from a datum (step cylinder .258 to .511 dia approx 1.5" long) to a .1015 dia cylinder approx 3/4" long. If I insert the step cylinder as the "primary datum" & the smaller cylinder in "feature" as the print calls out, I get no result at all. If I reverse the features, I get a result. Whats going on here?
A 3d Line and a Step Cylinder are two different axis lines.
A Step Cylinder takes all of your points to create an axis line. A 3d Line takes the center point of each individual feature, and draws an axis line.
To test, take 3 circle paths on a cylinder, and recall feature points into a Cylinder, and then use recall to create a 3d Line. Look at the actual values for the axis, they will be different.
Thanks for the input Richard.
I figured it out. There is a B/P note I missed, it states; "Applicable For Width -W-" which is located
above the center of the evaluated feature (a cylinder) I changed the evaluated feature to a constructed
3d line (now the 3d lines Z=0 is on the same Z=0 as width -W- and boom, I got a believable number.
