Is it right program?
Hello guys
I had an issue with program
In this program I created an alignment 1 for construction of 3D line for reference line.(please see the drawing). When I was checked manually the distance is coming perfectly.
But the problem is when I run the program, results are not came.(plz see attachment).
Why it's happening like this and my program is right or wrong.
If I am wrong please tell how to create the program for this drawing.
I want the distances (15 & 47 mm)
Thanks in advance.
IMG_20191018_013531.jpgFetching info... IMG_20191018_031510.jpgFetching info... IMG_20191018_031713.jpgFetching info... IMG_20191018_031540.jpgFetching info... IMG_20191018_031604.jpgFetching info... IMG_20191018_031623.jpgFetching info...
I'm unsure why you are creating the secondary alignment to generate a 3d Line, but your 3d Line is set to Options. That means you are physically measuring it. I assume you want a theoretical line, so drop down where it says Options, and switch it over to Theoretical.
