Chamfer in Gear Pro
I would like to see chamfer options in Gear Pro.
At a minimum the ability to input chamfer angle/size (nominal, and/or tolerances); at least for model construction, and so gear pro would calculate avoidance of overtravel on lead, etc.
Additionally, it would be nice if Gear Pro has an option to measure the actual chamfering.
As you may have seen on many new UTC cylindrical and bevel gears, they specify, the chamfer(x)the number of teeth. On First Article reports, some people want to actually see this many measurements. Even 4 places chamfer measurement would be a start.
Should be simple enough. Hire me as an Apps Engineer, I'll help. 😉
Oops, meant to post in Wish List
Thank you !
