Error with Curve/Program
I figured out how to get the program running but I still do not understand a solution. So this error pops up because for some reason my program populated two files named "curveParameter" & "curveTmp" in my results Folder and the error pops up because I had them hidden.
I do not understand why the files populated but I'm guessing it's because I had a CurveForm & Graphics Element characteristic...
Anyone?
Reason could be
If file is open by Standard Windows programs, like Notepad, Workpad or EXCEL therefor the file is write protected by System
I work with open source text-Editors (TextPad, Notepad ++) which are more comfortable and allows parallel handling.
Sometime the "bit" for write protection isn't reset, modify it by System command. CALYPSO allways Need fully access to text-files.
