[Ca...] Posted October 11, 2019 Share Posted October 11, 2019 I'm running parts in Autorun. The part are serialized, and the reports have to be tied to the serial number. Is there a way to force the incremental part number to hold to 4 places? Calypso is currently adding an additional digit, like: 0008 0009 00010 - this should (obviously) be 0010 Any advice? Link to comment Share on other sites More sharing options...
[Er...] Posted October 11, 2019 Share Posted October 11, 2019 It does stupid stuff since its a string, not a numeric value. Are you ok with resetting the number once the plan is started? if len(getRecordHead("partnbinc")) > 4 if subStr(getRecordHead("partnbinc"),1,1).asInteger == 0 setRecordHead("partnbinc",subStr(getRecordHead("partnbinc"),2,len(getRecordHead("partnbinc")))) endif endif Don't know if autorun will handle partnbinc diffrent from how its usually done. But you could give it a try. Link to comment Share on other sites More sharing options...
[Ca...] Posted October 11, 2019 Author Share Posted October 11, 2019 Thanks Eric. Link to comment Share on other sites More sharing options...
