Measuring difference between diameters.
I have an I.D. Datum at a Ø1.5732, at 4 equally spaced points along the diameter I have 4 radial cut outs that are supposed to be .016 bigger than the datum diameter. I can't figure out how to measure from my I.D. to these radial cut outs accurately. Attached is a very crude picture, paint skills aren't so great. Any help would be appreciated.
Size---->More--->Result Element
Or you can also right click in almost any empty field (like that Dia. field) and select insert a formula. (spelled formel in the documentation).
Right click on the box and select "Formula..."
Copy & paste that bit at the top of my first post into the box as shown.
Change Circle1 to whatever your datum circle is called.
Click "compute" to make sure everything is working correctly.
FYI, Make SURE that whenever creating formulas, if the number you're entering is less than 1, always use a leading zero. (0.016)
Otherwise you'll get a stupid err message but it wont tell you whats wrong.
