[SH...] Posted October 10, 2019 Share Posted October 10, 2019 In the drawing diameter 13 is an imaginary circle, I can probe radius six circle. How can I check the 1mm off set of the 13mm circle ,in pcdmis I can check it using vector features options, is there is any options in calypso creating a feature without probing. IMG_20191010_161049.jpgFetching info... Link to comment Share on other sites More sharing options...
[Ri...] Posted October 10, 2019 Share Posted October 10, 2019 You could scan a curve down the profile of the R6, and then use the Circle In Contour feature, and add the Ø13 that is tangent to the curve. Link to comment Share on other sites More sharing options...
[SH...] Posted October 10, 2019 Author Share Posted October 10, 2019 Please sign in to view this quote. Should I use circle in contour fit??? IMG_20191010_200907.jpgFetching info... Link to comment Share on other sites More sharing options...
[Ri...] Posted October 10, 2019 Share Posted October 10, 2019 Yes Link to comment Share on other sites More sharing options...
