Spheres
You create several circle segments (as many as will fit) in each sphere (lots of points)
and constrain size for location, location for size, which you can do in the characteristic.
If you have curve, I like slicing through the model (spheres) to create 2d curves, criss/cross
like a pizza. Scan and recall those points into the sphere features. I get better results this way.
I'd use nothing bigger than a 0.5mm stylus for the spheres.
https://qualityforum.zeiss.com/topic/17546-spheres/#findComment-98354
You can change the axis of the circle path inside of a sphere, so there is no need to perform this method. Just an FYI.
For most spheres, I have found that at least 1 circle path across each direction is the best. If you have a complete sphere, there is a new helical scan which I would suspect would be best, but I rarely get to measure complete spheres.
https://qualityforum.zeiss.com/topic/17546-spheres/#findComment-98368
