Spheres
How would you folks go about measuring the spheres for size & location on this part? This part is extremely difficult for us to hold consistently off the lathe so if anyone has better ideas than what I've come up with that would be awesomesauce.
You create several circle segments (as many as will fit) in each sphere (lots of points)
and constrain size for location, location for size, which you can do in the characteristic.
If you have curve, I like slicing through the model (spheres) to create 2d curves, criss/cross
like a pizza. Scan and recall those points into the sphere features. I get better results this way.
I'd use nothing bigger than a 0.5mm stylus for the spheres.
As i've said many times, i'm a huge fan of 12+ touch points when dealing with small and partial features such as Spheres, cones, Cylinder & radii.
It's never a very popular opinion, but it has served me very well over the years.
Here's a picture i posted in 2015
That's exactly what my method is. Using a 1mm. Repeats up to a .0001, so I figured it was accurate enough. Just trying to get the best results and repeat-ability possible.
You can change the axis of the circle path inside of a sphere, so there is no need to perform this method. Just an FYI.
For most spheres, I have found that at least 1 circle path across each direction is the best. If you have a complete sphere, there is a new helical scan which I would suspect would be best, but I rarely get to measure complete spheres.
You should only get that if the height goes beyond the sphere. Always start at 0, and work from there. It from the center, so it can be negative, and positive.
