O-Inspect Match
You need a measured base alignment first.
But you don't measure with the camera while picking something on the CAD. You can either show the camera view or the 3D view. Although you can have the camera image visible in the 3D view, it's merely a visualization of what the camera is currently looking at (to get that right you need the base alignment), but doesn't help you much when selecting CAD features.
https://qualityforum.zeiss.com/topic/17554-o-inspect-match/#findComment-98390
  • 4 months later...
I'm still having trouble with the camera not matching where I want to measure features on the CAD. Do I need to create the base alignment on the CAD model? How do I run it manually to get it to match the CAD?
I run the base alignment manually and then my camera goes off to where the CAD appears to be on the screen. What am I doing wrong?
https://qualityforum.zeiss.com/topic/17554-o-inspect-match/#findComment-98396
When you have a CAD to use, it's typically best to pull all of your base alignment features from the CAD FIRST, before you do anything manually.
Extract/define your base alignment features from your CAD, and then assign them to your base alignment. After your base alignment is properly defined, THEN perform a manual alignment. Now the CMM will know where your part is and the camera should be properly aligned to your model.
https://qualityforum.zeiss.com/topic/17554-o-inspect-match/#findComment-98398
This is generally a good idea in Calypso, no matter if you use tactile or optics. Never mix manual and CAD alignment. Do everything manually from the start OR do everything on the CAD an then align manually.
But if you have started without a CAD and did the whole alignment manually, you can then load a CAD model and both should still match. Of course the location of the coordinate system tripod on the CAD and the manual alignment must match too.
https://qualityforum.zeiss.com/topic/17554-o-inspect-match/#findComment-98400
