Why cant FF find its way around a corner?
I'm tired of having to create multiple scans to get around a corner, then stack them in order and send them to points then regather them into a single scan. this doubles or triples the time it takes to get around the part.
Fyi the surface in question is a straight wall "Cylindrical" surface, not a complex 3d surface.
Is there any reason you aren't using Curve?
In addition, if you are set on using Free-Form, then section the model at the heights you want to measure, and generate the path from the curve.
I don't use curve because i have surface profiles, not line profiles.
In the area shown here the surface i have is very narrow so im going around a perimeter, but i dont stay at the same level the whole way round, i have to move in & out to adjust for fixture and part edge.
On the wider segments i go back & forth on the surfaces at given spacing as required by our customer.
Plus i like the ease in which i can edit Free Form.
But i still wish it could find its way around a corner as easy as competitor software can (Start, Direction, End)
This is literally the only way I ever use Free Form. You have so much more control over the paths with curve.
