[Da...] Posted October 4, 2019 Share Posted October 4, 2019 I have a program with multiple mini plans setup within it, the operator selects the desired mini plan based on which CNC Machine the part is being produced on. Each mini plan has different reference dimensions that are specific to each CNC machine for getting the part dialed in. My question is, is there a way I can set up an input prompt at the beginning of the program to que the operator to select which machining center they are setting up and then Calypso runs the corresponding mini plan? Is PCM required for this type of action or is there another way? Link to comment https://qualityforum.zeiss.com/topic/17588-do-i-need-pcm-is-there-another-way/ Share on other sites More sharing options...
[Se...] Posted October 4, 2019 Share Posted October 4, 2019 you could create a desk in Autorun with multiple copies of your measurement plan, each copy pointing to a different miniplan? Name them as your CNC machines then all your operator will have to do is click the correct icon. Link to comment https://qualityforum.zeiss.com/topic/17588-do-i-need-pcm-is-there-another-way/#findComment-98686 Share on other sites More sharing options...
