Information on Printout
Hello,
How can I add extra information, extra fields (see 1.jpg; 2.jpg;) I know that I need to change something in (xxx_userfirlds.txt and zzz_userfields.ini) these two files, but what?
To add from the list of predefined parameters, go to "Measurements" tab, "Multiple Printout", "Select printout header parameters" button. If you check the box under "Run", an additional field will be added to the "Printout header data" fields in the "Start Measurement" dialog box. If you check the box under "Measurement", an additional field will be added to the "Resources", "Printout header parameters..." dialog box.
To add user defined header parameters, "Resources", "Design custom printout", "Editor for user-defined printout header variables..."
Hi,
Thank you, but this for multiple printout, but I have my own printout and without activated multiple printout it does`t work.
In RESOURCES-DEFINE PRINTOUT I choose my own form. Like I understood I need to do some changes in files: xxx_userfirlds.txt and zzz_userfields.ini But what kind of changes?
The editor for user defined printout header variables does exactly that. It's a convenient replacement for the manual editing of the userfields.ini. (I still prefer the old method though - just an old habit)
