Bolt Pattern
I have a part with a 4 hole pattern. There is a debate on if datum B is the one hole the leader line is pointing to or the bolt pattern. I think it is the pattern but I can not find an example of the datum indicator in this position on a bolt pattern. What do you guys think?
Bolt Pattern.pdf
