[ha...] Posted September 26, 2019 Share Posted September 26, 2019 Trying to use the characteristics feature to measure circle and cone by plugging the value of z axes from recall feature to get the projected circle on the cone at the certain heights. I would appreciator a solution ( using o-inspect 322) Link to comment Share on other sites More sharing options...
[Am...] Posted September 28, 2019 Share Posted September 28, 2019 If you are trying to get the diameter of a cone at a specific height you can use the Cone Calculation, It is under the Construction tab. In some version I have seen this named Cone addition, you will basically use your cone feature and then another feature that will determine the location of where the diameter is. If I could see what it is you are trying to do I could be more specific. Link to comment Share on other sites More sharing options...
[SH...] Posted September 28, 2019 Share Posted September 28, 2019 Please sign in to view this quote. I think you are talking about constructing a circle in a cone at particular height.Screenshot_2019-09-28-18-45-49-78.png Link to comment Share on other sites More sharing options...
