Pi web mmc problem
It is a numerical value of the percentage of tolerance used.
This helps you be able to perform Capability Analysis on a characteristic that has a moving tolerance.
True Position = 0.1920 - Tolerance = 0.3038 - Percentage of tolerance used is 0.632 or 63.2%.
It's weird that it is showing the .MMC with a tolerance of 0.2, usually it's with a tolerance of 0.1.
At the end of the day, it's for capability analysis only.
