Rename Stylus System
Hi all,
What is the easiest way to rename stylus systems without having to recreate them from scratch? I want to go to a new naming convention for my stylus systems. Can I export them, rename them, and import them back in? I'm trying to avoid any problems and not having to recreate and requalify every one, if possible.
Thanks,
Robert
https://qualityforum.zeiss.com/topic/17756-rename-stylus-system/
To make a copy of the entire stylus system, go to the same window "Stylus System Management" and select the one you want to copy in the left column, the click the Copy button at the lower right. You'll be prompted to give it a name, which will have to be different, but it becomes a valid, qualified copy of the original. You would, of course, need to qualify it if it WAS a different stylus system.
https://qualityforum.zeiss.com/topic/17756-rename-stylus-system/#findComment-99650
