[Ma...] Posted September 12, 2019 Share Posted September 12, 2019 I am tryin to measure the gap between an inner O-ring measured as a circle and an outer O-Ring measured as a circle. So there should be a gap in between these two circles measuring .130 or so but I am not sure how to get this measurement. Anybody have a similar issue. If you look at attachment imagine the O-ring not there. The inner wall and outer. I am trying to measure the gap. Ideas?Yamaha-Tz-250-350-Tz350-Cylinder-Head-O-Rings.jpg Link to comment https://qualityforum.zeiss.com/topic/17768-o-ring-measurement/ Share on other sites More sharing options...
[Ro...] Posted September 12, 2019 Share Posted September 12, 2019 Do you have PCM? it seems very easy to create a Large radius - small radius measurement in "result element". getActual("Circle1").radius- getActual("Circle2").radius Or, if you want super easy you can take a simple 2 point measurement from the inner groove wall to the outer groove wall. Use a 2ndary alignment, the diameter of the inside bore as your X&Y zero, and the top face as your Z Zero That would help extend probe life as well. Set your speed down pretty slow. Link to comment https://qualityforum.zeiss.com/topic/17768-o-ring-measurement/#findComment-99726 Share on other sites More sharing options...
[Ma...] Posted September 12, 2019 Author Share Posted September 12, 2019 Please sign in to view this quote. Thanks you 😃 😃 😃 Link to comment https://qualityforum.zeiss.com/topic/17768-o-ring-measurement/#findComment-99728 Share on other sites More sharing options...
[Aa...] Posted September 12, 2019 Share Posted September 12, 2019 PCM is not required to use Result Element Link to comment https://qualityforum.zeiss.com/topic/17768-o-ring-measurement/#findComment-99730 Share on other sites More sharing options...
[Ro...] Posted September 12, 2019 Share Posted September 12, 2019 Please sign in to view this quote. Good to know. Link to comment https://qualityforum.zeiss.com/topic/17768-o-ring-measurement/#findComment-99732 Share on other sites More sharing options...
[Br...] Posted September 12, 2019 Share Posted September 12, 2019 If you have curve, you can measure the two circles as 2D curves and use the "Curve distance" Characteristic. It can output the average width, the maximum width, or the minimum width of your O-Ring gap. Link to comment https://qualityforum.zeiss.com/topic/17768-o-ring-measurement/#findComment-99734 Share on other sites More sharing options...
[Ch...] Posted September 12, 2019 Share Posted September 12, 2019 Brett stole my idea but this is what I use for features that hold a seal or gasket. Then you can find your smallest or largest width. I have found that recalling regular features into a curve can be a pretty handy trick. Link to comment https://qualityforum.zeiss.com/topic/17768-o-ring-measurement/#findComment-99736 Share on other sites More sharing options...
[Ri...] Posted September 14, 2019 Share Posted September 14, 2019 The Caliper tool will do this. The suggestion to use Curve is also correct as it will show you the average, max, and min. Link to comment https://qualityforum.zeiss.com/topic/17768-o-ring-measurement/#findComment-99738 Share on other sites More sharing options...
