[Ch...] Posted September 13, 2019 Share Posted September 13, 2019 Guys, Does anybody use Calypso to also report the results of non conforming CMM measurements? For example, lets say a characteristic reports out of tolerance on the CMM report; However, when checked with other methods that characteristic is good. I have several tools to handle these kind of situations but none of them are within calypso. Deviations, NCMR's (non conforming material reports) etc. But all of these require generation another report on top of the CMM report. I've got some ideas but I'd like to see what you guys have come up with. PS. I have PCM and like to use it. Link to comment https://qualityforum.zeiss.com/topic/17774-non-conforming-reports-inside-of-calypso/ Share on other sites More sharing options...
[d0...] Posted September 13, 2019 Share Posted September 13, 2019 Measurement attribute with catalog : n.def / Re-check Flag measurement as re-check when characteristic OOS Re-measure OOS characteristic and replace value with value from other inspection method Use comment variable to leave note about what you did Link to comment https://qualityforum.zeiss.com/topic/17774-non-conforming-reports-inside-of-calypso/#findComment-99780 Share on other sites More sharing options...
