RPS alignment points application to True position
Good morning
If some of you have same problem please feel free to respond .
My part : Freeform automotive part alignment with RPS alignment
Coordinate origin is transfered from CAR zero point to Part ABC system ( origin in B )
A1/A2 are single point coordinates - fixation Y axis ( different Y coord )
B zero point XYZ
A3/C intersection of plane A3 and hole C YX axis
So : 3(y)-2(xz)-1(x)
Problem : In tolerance frame is defined to measure other position towards ABC system ( picture tolerance frame )
B/C are no problem to input but A1/A2/A3 are RPS points on radius not flat surface .
Is there a way to somehow do it , or drawing entry in this case is not correct ???
Let me know your ideas
BR
David
True position with RPS possible..JPGTolerance frame.JPGA1A2A3 example.JPGRPS PICTURE.JPG
